Keithley 2400 configured as a meter (not a source) in labview 2011
Hello all,
I am new regarding using Labview, and would like to ask you regarding an issue.
I am using Labview 2011 and have a Keithley 2400. I installed the latest driver provided by NI (1.2.5 I think), and wanted to get the readings out of the Keithley.
I checked the examples provided for Keithley but they were all dealing with the Keithley 2400 as a source (Voltage or current sources) and IV characteristics.
I wanted to use it as a current or voltage meter? Are there any way to do so?
Thanks in advance.
(3,903 Views)
Well, the 2400 is a Source Meter.  It does not behave like a DMM.  But the closest you are going to get to what you want is the IV characteristics example.  In it should be VIs for getting the measurements.
(3,901 Views)
