Keithley 2400 gpib labview connection
" I am trying to add a keithley 2400 sourcemeter device through GPIB 120 A Bus expander /Isolator , But The device is not being detected in NI MAX , I can't figure out what to do?
I have connected cable from pc to gpib ni 120a bus A and keithley 2400 is connected with Bus B.
(3,657 Views)
does it work when connected directly, so without the expander?
Is the keithley set to GPIB or serial?
greetings from the Netherlands
(3,598 Views)
Does the Keithley 2400 need to be isolated?  Are the computer/GPIB controller and the Keithley on separate ground planes?  Also, I believe that only one side of the GPIB-120A is isolated.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,584 Views)
I am trying to do something like this as well and am having trouble. I have installed the 488B driver before the hardware, like the instruction manual suggested. I also Have tried the driver with NI capability and with Keithley compatibility. I am using the Keithley GPIB so it is currently on the keithley compatibility install. The configuration utility picks it up but when i try and use a labview application ( the example ones such as Keithley 24XX Read Single.vi ect ... ) I get error messages. Mostly about VISA... my colleague says that yesterday it worked with an NI GPIB...
I am running Windows 7
Labview 2015
I checked for updated drivers this morning.
I am totally new to any of these tools, so any help would be greatly appreciated!
Emily
(3,360 Views)
