Keithley kusb-488A
Hi All,
We have Keithley kusb-488A  GPIB controller
I am able to use this for controlling keithley 2000 multimeter using example given by keithley instruments
when i try to use drivers downloaded from NI i was not able to control  keithley 2000
cant we use drivers provided by ni with keithley GPIB Controller
Pradeep
(5,869 Views)
Did you try and do a search of the forum? You would have found several posts such as this.
(5,866 Views)
Hello Dennis,
May be my question was not proper
i want instrument drivers for keithley kusb 488A
can we use instrument drivers provided in instrument driver network with kusb-488a
Pradeep
(5,844 Views)
You need a driver from Keithley for the controller. For controlling an instrument, you can use drivers from NI if the drivers use VISA  and Keithley has a VISA driver for it's controller. If an instrument driver uses low level GPIB, then you can modify the instrument driver to use VISA.
Message Edited by Dennis Knutson on 05-05-2009 05:15 AM
(5,831 Views)
