Keithley source and measure code
Hi all,
I an trying a code in Labview on Keithley 2400 instrument.
here my requirement is on my block diagram i want to write a program for source and measure and that can list out the any  error in that instrument once i run the code. it will list the errors like error1,error2,.......like that.
In the out put window i want to see the instrument serial number.
GPIB address
set volt, set current and limit.
display the error.
please suggest me how to do this.
(6,092 Views)
The driver should have an error query on the utility menu. Modify it for the extra functionality and save it with a new name.
(6,087 Views)
thanks for your reply,
do you have any capture for this.
(6,081 Views)
Capture of what? Did you find the function and look at the block diagram?
(6,079 Views)
i got it thank you.
(6,071 Views)
Could i get a labview program to measure dc current continuously. I want have a minimum of 1000 readings per second. I am really new to using scpi commands. There is always some error when i try to give any command apart from fetch? Could someone help me with an example program. I use keithley 2001 and visa resouce.
(4,582 Views)
