Keithley2400 voltage ramp rate
I am using Keithley 2400 and Labview because I need to make a ramp of Voltage from 0-5 V (initially). Although I read it at the graph in Labview, I can not see the same signal at the scope. Thus, I would like to understand what is the rate of increase of the ramp and try to control it. This ramp block is tricky for me to understand, could you please indicate how I can set the rising time and make it slower/faster please? I tried to find an example for ramp but didn't find any. Do you see any error in my code?
I have attached the screenshot of the scope and what I see at Labview too. Please help !
Thank you in advance!
(6,043 Views)
Ok, just updating, my signal is correct now. It seems there was an external disturbance but I eliminated it.
It looks like a ramp with a rising time 100 us now. So my question is, how can I make this ramp slower , ie. some ms or even seconds?
Thank you in advance !
(6,039 Views)
Hello, any update on this please? If it is not the right place or if there is a specific forum for Keithley please indicate !
(5,954 Views)
(5,949 Views)
You can add more points ore even more effective change the integration time of the 2400.
greetings from the Netherlands
(5,937 Views)
