Keysight PCIe-GPIB with labview
Hi
I have a problem reading the instrument addresses in labview 2021 with Keysight PCIe-GPIB card. I can read the addresses from e.g. NI MAX and manually enter the address in the labview program, but it would be convenient if labview could find it.
The procedure I used when installing was:
-Install Labview 2021
-Install IOlibsuite downloaded from https://www.keysight.com/se/en/contact/support/software-download.html
- Enable Keysight GPIB cards for 488 programs in Keysight connection expert.
- Open NI MAX and check  NIVISA Tulip.dll
-also in NI MAX Disable Keysight VISA.
Best regards
Tommy
(1,544 Views)
Can you explain what problem you have ?
(1,482 Views)
