LabMax TOP calibration password
I have some question regarding Coherent Power Meter. I'm try to implement my code to use the LabMaxTop's LabVIEW VI "CH_LM Reset.vi". It was referred to a calibration password. How do I find what the password is or how to set it. I already checked on the user manual but there is nothing about a calibration password. Please advice.
(5,834 Views)
Probably a question better asked of Coherent, I think they wrote the vi's.
(5,824 Views)
Thanks for you post.  Which instrument are you using and where did you get the instrument driver?
Todd V.
NI Prototyping Community
(5,794 Views)
We are using Coherent LabMax TOP Laser Power/Energy Meter. I've downloaded the instrument driver from Coherent web site.
We are using Coherent FieldMaster at the moment but it will be obsolete this year and I'm try to write the VIs to replace those. I'm try to find way to reset the LabMax TOP's power meter (reboot a power meter). I've found that FieldMaster is using "*rst" command but I also found that LabMax's Reset is actually reset the realtime clock which is totally difference from FieldMaster. I just wonder if there is some way to reboot any power meter.
I couldn't find thier forum so I thought I've post it here - just in case somebody know something.
(5,789 Views)
Thanks for the quick reply.  Since this is an instrument driver that is not certified by National Instruments, it is not supported by our Applications Engineers.  Hopefully we have some customers who might have some experience with this driver who can help you further.  Have a great day!
Todd V.
(5,772 Views)
We recently have a need to look at interfacting to a LabMAX TO, I've been digging though the vi's I download from Coherent today.
Try calling CH_LM Calibration Password.vi first to set the password first. There are hints spirnkled in File/VI Properties/Documentation.
Know this post is a bit old, hope it helps.
-AK2DM
(5,543 Views)
Thank you for your info. I appreciate you spent time look through those VIs.
(5,528 Views)
