LabVIEW Add-On for Tektronix Oscilloscope Problem
I installed the labview add-on for tektronix oscilloscopes and all the pre-requisties on my computer.  I was looking to use the custom scope vis installed with the add-on, but some of the files are missing.  The functions palette contians some of the vis, but is missing the initialize and close vis.  Also, when trying to run an example many if not all of the subvis are missing such as the tktds7k set aquisition state.vi and tdtds7k set wfm display status.vi.  Any help or suggestions would be very appreciated.
(4,018 Views)
Hi
Which add-on from which source do you mean?
greetings from the Netherlands
(3,998 Views)
I am using the "LabVIEW Add-On for Tektronix Open Windows Oscilloscopes Version 1.2" with Labview 7.1 on Windows 2000.  I am trying to control a tektronix 7154B oscillosocpe with Labview.  I also downloaded NI-VISA 3.6 and the tektronix tekscope ivi-com driver.
(3,982 Views)
I don't see anything by that name on Tek's site. I downloaded the LabVIEW and CVI driver from http://www.tek.com/site/sw/detail/1,1059,3107,00.html and I have a full palette of functions. You probably want to avoid the IVI-COM stuff.
(3,979 Views)
Thanks for the help.  Seems to work a lot better.
(3,943 Views)
