LabVIEW IO Control: Can I break them down to DeviceName, and SessionNumber ?
I use the LabVIEW IO Control to initialize a device and I pass the inputs from Test Stand. Test Stand breaks them into: DeviceName and SessionNumber.
Is there a way in LabVIEW to do the same thing ? I'd like to be able to break or "unbundle" them in LabVIEW. Thanks y'all !
Kudos are the best way to say thanks 🙂
(4,374 Views)
Hi SK8,
Could you please give me some more information on what control you are using and what type of device you are initializing (DAQmx, Serial, GPIB, etc.)?  A screenshot of the piece of code in question would be helpful.  It is likely that the information you are looking for is accessible through a property node for the session you are initializing, but it will be different depending on the type of session.  I would recommend starting to look there.
Happy Holidays!
Andrew T.
(4,357 Views)
It is  the IO Control for NI-Sync (T6674 Timing card). I've attached a small screenshot. Basically what I am trying to do is this: I am passing inputs from Test Stand to my VI for the IO Control. I'd like to do that as a bundle of 2 strings (Session Name, Number) and them bundle them inside my VI to pass to NI-Sync.
(4,353 Views)
This property may be driver dependent so it may be helpful to know what hardware you are using, as well as the drivers you have installed. I hope that you have a nice day!
Jason D
(4,326 Views)
Hello Jason
The hardware is NI PXIe-6674T. Here is a screenshot from Max. Happy Holidays !!
(4,314 Views)
You can get the device name in a string type by passing the instrument handle out to a "Type Cast.vi" and casting it to a string type. Unfortunately you can not get the IVI session number in LabVIEW.
-Jake B.
(4,297 Views)
