LabVIEW and ICP M-7055
Hi, im newbie on LabVIEW; ei have a school project with the ICP M-7055 module ( http://www.icpdas-usa.com/m_7055.html ); i wanna know how to communicate with this module... I found this: http://ftp.icpdas.com/pub/cd/8000cd/napdos/driver/dcon_labview/  and it extract:  DCON_gen ( LabVIEW LLB ), uart ( LabVIEW LLB ), DCON_PC.dll, Uart.dll y and 3 folders with examples ( VI and SubVI  ) but i donw know how to use it.
Someone have experience with this module?
THANKS!
(5,313 Views)
Hello aacosta,
That module in particular seems that it doesn’t have any official drivers for LabVIEW but it’s built in Modbus RTU and RS-485 which both are supported in LabVIEW meaning that you need to build your own drivers for this module.
I leave you some links that will help you with this task:
Introduction to Modbus:
Serial Communication Starting Point
You can also check the Find Examples… section in LabVIEW for some .Vis that perform Serial communication.
Hope this information works for you.
Luis CT
(5,287 Views)
