LabView and digital outputs
I been trying to get Digital I/O to work in LabView 2013, using an ni 9474 Daqmx. Any help would be3 greatly appreciated . I have attached some code I have been trying below. Obviously ,I have greatly simplified the while loop.
(1,342 Views)
A port is a single channel.  So use a U8 for the value and change the DAQmx Write to the 1Channel, 1Sample, U8 Port.
(1,332 Views)
