Labview 4.0
I am retriving an old control program that is missing the file "compute waveform.vi" for labview 4.01.
I am using the labview upgrader software.
All I can get on the web are recent versions of "compute waveform.vi" taht are not compatible with the upgrader.
Please send me a "compute waveform.vi" from the time of labview 4.01 (around 1995).
Thanks!
  George
(3,351 Views)
Hello George,
I am not familiar with that particular VI, but I believe that it was one that came with a much older version of our NI-DAQ (traditional) driver.  If found reference to it in the following tutorial Transition from Traditional NI-DAQ to NI-DAQmx.  I am guessing that you are performing some analog generation in this VI you are upgrading to a newer LabVIEW version.  If you would like to indicate what that particular VI does, someone might be able to provide you with the newer version to replace.
Travis M
LabVIEW R&D
(3,326 Views)
