Labview driver for Agilent 33120A
I downloaded and installed the driver for LabVIEW 6.0/Windows2000 from the NI website. When I try to place it in the block diagram window, the functional blocks (e.g., application examples) are showing as big "?" marks and are unusable. Any suggestions on how to fix this problem. I have downloaded other drivers the same way, and they are working just fine.
Thanks...........
(3,711 Views)
To help debug this, try choosing File->Open and opening one of the VIs directly. (In the LabVIEW "instr.lib\ag33xxx" directory.)
Do you get a more meaningful error message?
Brian
(3,711 Views)
Another thing you can try is to open LabVIEW and do the following. Click [Edit]>>[Preferences]>>[Paths] and make sure that the default path is set to C:\Program Files\National Instruments\LabVIEW. If the "default" option is checked, uncheck it and type "C:\Progra~1\Nation~1\Labview" (without the quotes) and click the [Replace] button.
Please let us know if you can open the VIs individually as earlier recommended.
I hope this helps!
-Joe Des Rosier-
(3,711 Views)
