Labview driver for omron
Where can I find instrument driver for Omron E5CK controller? I need to communicate with the controller using Labview via RS-232C.
(4,152 Views)
Unfortunately, there are no drivers listed for this instrument at http://ni.com/idnet. You may want to contact the manufacturer to see if they have a LabVIEW driver for their instrument. If they don't, you can easily create a low-level driver by configuring an I/O assistant VI for each function in the manual. I/O assistant is one of the many new features of LabVIEW 7 and will parse instrument responses for you, which makes creating an instrument driver much easier. Once you have this low level driver you can just combine functions to make higher level VIs. Alternatively, you can hire an Alliance Member to write an driver for you.
Alliance Member Directory
http://www.ni.com/alliance/alliance_member.htm
(4,152 Views)
