Labview program for Keithley 236
I am trying to control Keithley 236 source unit using GPIB/labview in windows XP.
I need two vi programs.
1)Current Vs. Voltage i.e. increasing voltage in steps with an adjustable hold on time
2) Current vs. time with a fixed voltage. i.e current measurements with time, with adjustable intervals and hold on time.
I would really appreciate if you could send me the programs.
Thank you very much
G.N
(4,078 Views)
There is a driver available for that instrument. You should be able to create your progam from the functions that are in the driver. There is even an example that shows how to implement a sweep.
(4,070 Views)
