Labview program keeps freezing
Hi Labview Users,
I have a vi that keeps freezing a few minutes (~15mins)  after I run it. I don't know what causes the vi to stop responding. Sometimes I would open it up and when I click run it runs but no data display shows up on the front panel. I have attached the problematic vi. Any ideas?
Thanks.
-Sicelo
(4,510 Views)
It will be better if you attach your code, so that someone will help you.
(4,500 Views)
~~~~~Oh  Magic 8-ball does the OP have a USB device connected as the data input?~~~~~
Probably.  Better check the windows power options on the USB Hubs
some error handleing woud help.  Do you ever check the error status?
(4,495 Views)
Hello Labview users,
I am writing back about the same problematic vi that was giving me problems a month ago. I still have not solved the problem, which is quite sad for me.
I thought I attached the front panel and block diagram so that people could help me. What exactly do people mean when they say can you post the code?
This vi is weird because it is not broken or anything when I run. It runs fine for the first few mintues when I click run and then freezes after like 15 minutes. I think it gets flooded with so much data that Labview just freezes on me.
Any ideas on what I could do to stop this problem?
Many thanks.
-Sicelo
(4,459 Views)
You attached pictures. Attach the VI itself. No one can debug a picture especially one where you have hidden code.
(4,457 Views)
Here is the VI that keeps freezing after a few minutes.
(4,441 Views)
