Labview reads gas analyser serially
I am using Licor IRGA 840 and 850 for data acquisition in NI Labview. I am receiving different values simultaneously when read through IRGA software and Labview software. Both these values are off by more than 10ppm. I have synchronized the baud rate, parity and stop bits but still the problem persists.
Please let me know if you have any solutions regarding this.
(690 Views)
The accuracy for this equipment is listed in their manuals as:
> Better than 1.5% of reading.
You list how much it is off, but not the reading.  What is the reading?  Is 10PPM better than 1.5% of reading?
Can you show us your LabVIEW?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(652 Views)
