Lakeshore Temperature Controller 325
I am currently trying to connect a LakeShore Temperature controller 325 to a Window 7 PC for the purpose of controlling of its functions by remotely logging into the machine. Currently we are using Labview 2012. I download the project file from the NI page as well as the appropriate driver but am not able to get the actual equipment to be seen by Labview. As far as I can tell this is my last step in successfully setting up this interface but I am completely stumped as to why this isn't working.
As a side note: There was also visual basic code that came with the temperature controller that seemed to be having the same communication (or lack there of) problem as Labview.
(4,005 Views)
not "seen" by LabVIEW?
what does that mean?
Is this a GPIB instrument or something else?
(4,003 Views)
It is a GPIB connected temperature controller. When I try to communicate with it from the from panel of my program I can neither send nor recieve data.
(3,934 Views)
Since you say that their included software doesn't work either, then you should contact Lakeshore.
(3,930 Views)
