LeCory 9370 scop vi
It took me some time (it's heard to learn LV while you really need to learn QM and so on). Finally today I have it! This file is pretty much what I wanted...
This VI uses a LC pre made VI to read the waveform, then an FFt filter and some data is extracted from within the cursors defined there. This VI is just one part of a more sophisticated one, but this is the part that gave me heard time...
Thanks for the help you guys gave me!
Message 11 of 13
(1,471 Views)
Hello again,
Once again I am in need for some assistance. The oscilloscope is set to read when an external pulse is given, but my VI samples the scop several time during that. The solution I have now is to compare parts of the waveform and then decide if the waveform was read multiple times. I would prefer it if I could the waveform just once per trigger, I was unable to find a function for that in the LC97xx driver.
Did I just miss it? Is there a "smart" way of doing this?
Message 12 of 13
(1,452 Views)
I would suggest reviewing the LabVIEW shipping example Acq&Graph Voltage-Int Clk-HW Trig Restarts.vi.  This can be found by navigating to Help » Find Examples... within LabVIEW.  This example shows how to acquire a finite amount of data (waveform) each time an analog trigger condition is met.
The way you are collecting data right now, it is constantly collecting a waveform within a while loop, so it makes sense that you would see it repeatedly.
Let me know how that goes!
Shawn S. | NIC
Instrument Driver/IVI PSE
Message 13 of 13
(1,439 Views)
