LeCroy LT322 Where is SubVI ?
Dear Sir;
I am trying to control Lecroy waverunner LT322 osciloscope with Labview 6.0. I downroaded the instrument driver. But when running the VI, SubVI is needed for the program. How can I find the SubVIs for the LT322 VI?
Best Regards;
YK
(4,429 Views)
Check in the .llb that came with the driver.
Ben
(4,429 Views)
Dear Ben,
Thank you for your response. The program tries to load the lcltxxxx_32.dll file in some libraly, when running any VI in lcltxxxx.llb. But I cannot find the DLL file anywhere. Plaese show me how to solve the problem.
(4,429 Views)
Make sure tour browser is not set to "Hide system files".
Otherwise go back to where got the .llb and see if you can find the .dll.
Ben
(4,428 Views)
I found the lcltxxx_32.dll file in c:\VXIPNP\WINNT\Bin. But when selecting the DLL file, I met the error notifying "The procedure entry point_ResetCalledFunPtr could not be located in the dynamic link library instrsup.dll"
The LeCroy VIs still do not work. Please show me what I should do next.
(4,428 Views)
