LeCroy read and writhe Osziloscope settings
Hey,
I just started with using Labview. I am using the LeCroy LT374L Osziloscope and want to read and write the complete Osziloscope settings (like trigger level, offset and so on ) first read and save on the PC and later write them back into the Osziloscope.
I am using Labview 2010 with the driver lcltxxxx, up to now I could not find the right VI to realize my idea.
Does anybody has such an Problem solved before or can help me with my Problem?
thanks,
Christian
(3,707 Views)
It would be a very rare driver that had functions to read the state of an instrument. Typically, you just have functions to set parameters. The SCPI commands to query a setting are simple and will be documented in the manual. You can add specific functions to the driver or modify the existing ones to do either a read or write.
Why do you want the ability to read the settings? Is this to allow a user to manually setup the oscilloscope (note the correct spelling)?
(3,700 Views)
