Legacy driver for HP 33120A?
I inherited a VI with inst driver subVIs for the HP 33120A that include "HP 33120A -- Select Arbitrary Waveform.vi," which isn't among the subVIs in any of the idnet LV drivers. So, is there a legacy driver out there (will otherwise fiddle with related subVIs in the ag33xxx.llb)?
(4,216 Views)
Hi ret,
I believe you are looking for the following driver (see attached).
I hope this helps.
Best Regards,
Vesna
(4,216 Views)
Vesna,
Thanks -- that was what I was looking for. I had one trivial problem at first: the Init VI was broken, but I fixed that by reassigning a parameter from a VISA Set Timeout node (which I subsequently deleted) to the timeout input on an Old VISA Open VI. Apparently, VISA 3.1 isn't backward compatible with the VISA calls in your inst driver. I wonder if this explains why your driver wasn't available at ni.com/idnet?
(4,216 Views)
