Loading and warning
I recived autowave Driver from Ametek. I copied everything into the right directory which is C:\Program Files (x86)\National Instruments\LabVIEW 2017\instr.lib. But I am still getting dependecncy warning, when i try to load a VI called Initialize. As a result I cannot find the Instrument from the Instrument handler in.
Fazlay
(1,771 Views)
The first time you open the Vi or project you will see these warnings, because the paths are slightly different.  Save the files when you close and then the next time you open them the warnings are gone.
This should not prevent you from running the VI properly as there were no Error messages, just warnings that dependency locations had changed on disk.
(1,737 Views)
Hello cstorey,
Thank you, the warnings are gone unfortunately, I some other issues. I have made a clear post about it in here. If can take a look.
Error BFFC003 Parameter 3 out of Range - NI Community
Best Regards
(1,704 Views)
