MAX Crashes
I am using GPIB PCI from cyberresearch. when i try to run Max to scan for instrument the software crashes. but i have installed the driver for the card. the getting started wizard of labview also does not verify the interface. please help me
bye
karthik
Message 1 of 9
(4,962 Views)
Hello Karthik,
MAX is designed for use with National Instruments GPIB, data acquisition, and other NI products. The NI-488.2 Getting Started Wizard will not work with other GPIB products. If you would like to standardize on National Instruments products, see this link for our PCI-GPIB card:
http://sine.ni.com/apps/we/nioc.vp?cid=1233〈=US
Scott B.
GPIB Software
Message 2 of 9
(4,962 Views)
Karthik,
I'm also confused because MAX should not show any third-party GPIB interfaces and thus you should never be able to click on "Scan For Instruments". Do you mean that MAX crashes when you first start it? Or can you actually see a "Scan For Instruments" button? Do you have any National Instruments GPIB cards in the system? If you have NI-488.2 (our driver for our GPIB cards), what version do you have? Have you loaded the Cyber Research drivers as well?
I'm interested in this information if you're still monitoring this thread.
Scott B.
GPIB Software
Message 3 of 9
(4,962 Views)
Hi Scott,
but when i tried to put my third party GPIB card on a different machine max found the intrument and communicated with it.
bye
karthik
Message 4 of 9
(4,962 Views)
Karthik,
Can you be more specific? Was this the Cyber Research card? Did it show up as GPIB0? Did you have NI-488.2 loaded? What version? Did you have the Cyber Research driver loaded? Did you have any other NI GPIB card in the system? Can you provide a screenshot?
Scott
Message 5 of 9
(4,962 Views)
Hi scott,
It was a cyber research GPIB card. In the getting started wizard it shows a error. but when i used Max it scans for the instrument and communicates with it.
bye
karthik
Message 6 of 9
(4,962 Views)
Hi Karthik,
If you could answer my other questions above, I would appreciate it. I'd really like to figure out why this works at all!
Scott
Message 7 of 9
(4,962 Views)
Hi scott,
I showed as GPIB0 in the MAX, but in the Ni 488.2 it gives interface not configured. i have installed cyberresearch driver for this card and i dont have anyother NI GPIB card installed. i have attached the screen shot.
Bye
Karthik
Message 8 of 9
(4,962 Views)
Karthik,
Very interesting. Unfortunately I cannot help you since the Cyber Research software modifies certain National Instruments files and I do not know how those drivers work. You will need to talk to them to get your problem solved.
Scott
Message 9 of 9
(4,962 Views)
