MAX does not detect my USB-GPIB-HS 488.2 instrument, but the Windows XP Device Manager does
I have a problem when using the USB-GPIB-HS 488.2, I can see the device in the Device Manager from Windows XP, but it is not visible in the MAX, I don't even see a section for the GPIB devices; however, when I try to install a new GPIB device, the MAX Wizard tells me that there is one GPIB instrument installed in the computer which GPIB0       -      USB-GPIB-HS. Do you know what is the reason for this to happen, because I want to use a multimeter in LabVIEW via GPIB but I can't access it, I don't even see that there is a GPIB connection in the computer (in LabVIEW).
Alejandro Rodriguez
(4,743 Views)
Alejandro Rodriguez
The GPIB controller is GPIB0
(4,731 Views)
You don't have anything at all listed under Devices and Interfaces in MAX? What version of NI-488 do you have installed?
(4,729 Views)
Hi Dennis_Knutson
I do have items listed below the Devices and Interfaces in MAX.
 -  Network Devices
 -  PXI Systems
 -  Serial & Parallel
     - COM1
     - LPT1
     - LPT3
but I don't see the GPIB section, even though when I try create a new GPIB Interface it says that there is one installed.
What do you mean with the version of NI-488?
If you mean the driver version is 2.4.0.3500
(4,727 Views)
Accepted by topic author alejandromxl
That's kind of old. Have you tried the latest?
(4,713 Views)
Thank you, apparently it was a problem with the driver, as soon as I upgrade it, it works!
(4,698 Views)
