MAX does not see serial instruments through PCIe 8430
I just installed a PCIe 8430/8 and put the instruments on ports 1 and 2 respectivley.  When I try to query the instruments in MAX I get no responces from any of the ports.  This is usually trivial and frankley Im not sure what the problem could be.
(3,410 Views)
Have you tried to do a serial loopback test on the cables to see if the cable is the problem?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YFtECAW&l=en-US
Has this board ever worked before? Have these instruments ever worked before? This sounds like there is a hardware problem somewhere, you will just need to narrow down exactly where.
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
(3,384 Views)
