MAX doesn't see the COM ports
The program works fine on the development machine (using VISA). Port doesn't init when the exe is run on client machine. I installed MAX on the client machine, AND IT DOESN"T SEE THE SERIAL PORTS but windows control panel does. why can't LabVIEW or MAX see the ports
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
(3,277 Views)
Did you try hitting "F5" in MAX?
Did you install NI-VISA on the target machine?
Ben
(3,277 Views)
