MAX .nce file with CVI 2010?
Is there a way to progromatically load MAX .nce file using CVI 2010?
(3,401 Views)
I guess you mean to load the nce file via programming in CVI.
Basically, the import/export feature has a command line interface: nipcrun.exe. The location of this file is  "D:\Program Files\National Instruments\Shared\Portable Configuration".
Export non-interactively: "nipcrun -ni 127.0.0.1 test.nce".
Import non-interactively: "nipcrun test.nce 127.0.0.1".
Add -s flag after nipcrun.exe could invoke the import/export in silent mode.
- Charles
(3,396 Views)
