MS2026A
Dear Mr./Mrs I connect the Anrtisu MS2026A Network Analyzer to PC by Ithernet connection. The IP is ok, by using MAX I install my new device...
I used Labview 8.0 program..Some errors occured..I cannot undertsand...I use Visa Open, Write, Read and Close..., but show error, and if i write network commands same problem...I need your help..
If you have the program of MS2026A, please attach the file....I want to measure S11 by using labview.
Please help me...
Thank you in advance...
Harut Melikyan...
(3,127 Views)
If you are getting an error, you have to post the error code if you expect anyone to be able to help.
(3,121 Views)
