MSO-X 3102A Drivers
We just received the Agilent MSO-X 3102A 1 GHz mixed signal oscilloscopes, will the Agilent 2000 3000 X-Series instrument drive work with it or is there a driver that will be relased in the not to distant future?  We are using LabVIEW 2011. Thanks.
JoeD
(3,694 Views)
If MSO-X 3102A shares the same command set with other models from the MSO-X series, then there is a good chance that the existing driver will work. You can either try to diable the ID Query in the Initialize VI, or make a slight update in the Initialize VI to add your model to the list of all other models on the block diagram.
(3,689 Views)
Thanks that seems to work I can now setup the scope and the wave generator.  It doesn't appear to have all the functionality on the wavegen side but I am sure a true driver will come down the road.
JoeD
(3,686 Views)
