Mac VISA/USB : STB timeout bug?
I appear to have run into a bug in the Mac USB implementation of the VISA STB (Read Status Byte) function. If I set a long session timeout, the VISA STB function waits that long to return, even if the instrument returns the status quasi-instantaneously. With the default timeout value, all is well.
This is not the behavior under Windows.
As a work-around, I restore the default timeout before reading the STB.
-- Philip
(4,087 Views)
sorry for the late reply!
Can u post your code please?
Which VISA-Version are you using?
regards
Marco Brauner NIG
(4,044 Views)
Dear Hans,
Thanks for the reply. Just so you know: in the meantime, I have also posted a support request by e-mail (Reference#7209437), which went to NI Switzerland (Laurent Pollara-Brevart) who has forwarded the question to the US.
I am using LabVIEW 8.5.1. I am attaching our low-level VI that writes a command and reads the response and any errors, plus its sub-VIs. If you use the default command (*IDN?), it should work for any IEEE 488.2 compatible instrument. In this version, I change the timeout value on the VISA session just before calling the VISA STB function; by default, I have it at 10 ms. You can play with this value, and observe that the VISA STB takes exactly that amount of time to return.
Thanks again,
-- Philip
(4,015 Views)
