Making signal Mean
I am aquiring data in a "while loop" (loop 1)  at a rate of 80 S/s. I want to know the mean voltage from the data at each second. I've try to use a local variable (data) in a "for loop" in a second "while loop" (loop 2) that iterate at each second. I don't know why, it is not working. I've sent an exemple to explain what I am saying.
Thank you
Francois
(3,145 Views)
Only once in a second you copy one value to the other while.
That is not enough to calculate a mean from.
You should accumulate 80 samples in an array (or add up in a value) and use this to output a mean
You even can output a mean 80 times a second this is called a walking (running) mean.
see attached example
the second while uses the point by point mean this helps a lot and gives a good result even when not yet filled
greetings from the Netherlands
(3,141 Views)
Thank you Albert,
Can you send me a screen shot of your vi, my version of labVIEw is 7.0 and I can't read your program.
Thank you again
Francois
(3,139 Views)
here is the 7.0 versie
(3,123 Views)
