Maximum byte count in Receive() or ibrd()
What is the maximum number of byte count to use in Receive() and ibrd()?
(3,345 Views)
The byte count is currently limited by the amount of free physical memory in the system. The driver must page lock the buffer to perform the transfer. If you need to transfer a very large amount of data, you can perform multiple reads to read the data.
Craig A.
National Instruments Engineer
(3,345 Views)
