Measure gain with Tds220
I want to measure the real gain (positive or negavite) of an inverting amplifier.
First step I measure the absolute value of gain (out dp over input dp) and in second step i sum the input waveform and the output waveform, and if the sum is zero the signal will be inverted by the amplifier.
But this solution doesn't works.
(3,158 Views)
Please define "doesn't work". Are you getting the wrong values from the scope? Are you getting errors? Is the instrument locking up? Does your device blow up?
One general comment: while LabVIEW may be multi-threading capable, most communication protocols are not. Thus, it's best to make sure that you don't try to send out a command while you're waiting for a response from another command. Thus, your writes and reads should be a continuous chain, not separate, independent sequences.
(3,148 Views)
