Measurement and Automation Explorer
When trying to access my remote systems I get the following error message:
 < The niVISAui.mxx plug-in caused an exception in the CmxProviderWrapper::BindPrimary function in the NIMax process. >
Any help would be greatly appreciated, thanks.
(4,486 Views)
Hi duhaime26,
Could you provide some details on your system hardware and software. Has anything changed in the system recently that you are aware of? Also, if you ignore the error are you able to access your remote systems? Are there any other errors or odd behaviors occuring other than this error?
David C
(4,443 Views)
