Microwave Filter Testing in LabView
I would like to if there is any example programs written in LabView to test Microwave filter parameters. I would like to test a filter using an HP 8753 Network Analyzer and record the VSWR, Passband, and rejection performance.
(3,550 Views)
You could find a driver for this instrument at http://www.ni.com/devzone/idnet/default.htm and probably some Microwave filter examples from google.
If the instrument driver not listed there, it leaves you with one of a couple options. First, I would like you to submit a request for this driver at: http://zone.ni.com/idnet97.nsf/instrumentdriverrequest/
We develop drivers based on demand and popularity so the more requests we have for it, the greater the possibility that we will develop one.
If you would like to try developing your own instrument driver (or modify the existing one), we have documentation, model instrument drivers, and driver templates to help at :
http://www.ni.com/devzone/idnet/development.htm
We also have a syndicate of third party vendors that specialize in National Instruments' products and services. Some of the vendors specialize in driver development. I would suggest contacting one of the Alliance members at:
http://www.ni.com/alliance
An instrument driver is a collection of functions that implement the commands necessary to perform the instrument�s operations. In short, someone read the instrument user manual and implemented some of the functionality in a program for the end user. Instrument drivers are not necessary to use your instrument. They are merely time savers to help you develop your project so you do not need to study the manual before writing a program. With all of this work already done for you in the driver, instrument drivers can significantly reduce development time.
There are example VI's in LV on Instrument Connectivity. If you go to the Help menu >> Examples.. >> I/O, you will see a couple and Examples.. >> Fundamentals for File and String manipulation. I would suggest tweaking them to suit your application. Also the specific command that your instrument responds to can be found from it's manual.
Some useful resources for your application are
ni.com > NI Developer Zone > Development Library > Instrument Connectivity
http://search.ni.com/?col=alldocs&layout=TechResources&ql=a , to search examples and knowledge bases
http://www.ni.com/support/
Hope this helps.
(3,550 Views)
