Modbus Serial Master Query.VI ---> TIMEOUT ERROR???
Hi
I am using the National Instrument Modbus Serial Master Query.VI to control a modbus device from labview.
It is working but I keep getting a timeouterror. I know there is a timeout issue with pc&modbus but I dont know where to change the timeout except for the obvious frontpanel of the NI VI. This doesnt help. Has anyone used this VI and understand my problem?
The Error code is:
"Error 6101 occurred at Timeout Error
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input."
Fredrik
Message 1 of 8
(7,885 Views)
Hello!
I haven’t used the VI in question and have never programmed against a modbus device, but I searched on our databases after similar reports on this error and unfortunately I didn’t find any useful information.
The only thing I can suggest is that you increase the timeout terminal on the VI in question just like you have done.
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
Message 2 of 8
(7,841 Views)
hi,
I never used Modbus Serial Master Query.VI, but using the ModBus driver available at this URL
http://www.saphir.fr/GB/products/drivers/modbus/index.htm
allows you to set the timeOut delay for all your querry.
An exe demo is dowloadable here :
http://www.saphir.fr/GB/products/downloads/index.htm
you can test modBus communication with it.
Hope this can help you...
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Message 3 of 8
(7,826 Views)
Hi Fredrik,
I have the same timeout error problem. Did you solve it in the end (and if you did, what was the solution)?
Jurry.
Message 4 of 8
(7,733 Views)
I am also experiencing the 6101 timeout error.
Has anyone found a solution for this?
Gabriel
Message 5 of 8
(7,349 Views)
Generally timeout errors are due to the device you are trying to communicate does not recognize a command and therefore does not return any data.  Try sending some commands that you are confident the device will understand to make sure that you have a connection.  The error could also be due to the messages being too long.  Increasing the timeout will fix this issue.  Also, be aware that if you double click on the Modbus icons when they are on the block diagram you can edit their source code.  This can be helpful if you need to customize the way your program runs.
Scott G.
AE Specialist
Message 6 of 8
(7,263 Views)
I also have this error, I have done what we have suggested, but still leaving mistake.
How could someone help me?
Message 7 of 8
(6,837 Views)
Hello Francis,
Do you have any more specifics as to what you've tried. As Scott_G mentioned, these timeout errors are usually caused by either incorrect commands going through or an overflow/undeflow of data. Have you also gotten anything to work on your system, or is this the first time you are doing this?
Let me know
Can Wong
Message 8 of 8
(6,812 Views)
