Modbus library for Labview6.1
Hi!
I was seeking for a Modbus library and found one available for Labview 7.1. My version is 6.1. Does anyone knows if there is one similar library to work with Modbus within Labview 6.1?
Marcio
(3,521 Views)
Hi Marcio,
I do not believe there is a downloadable library from the NI Developer Zone for Modbus in anything but LabVIEW 7.1, but I did find a Knowledge Base article with a link to an NI Alliance member who seems to do some work with Modbus.
Do LabVIEW and LabVIEW Real-Time Support Modbus?
I also briefly saw some posts where some customers have found some Modbus VIs by doing a google search, perhaps this could be successful for you as well!  I hope you are able to find something that fits your needs, either through upgrading LabVIEW, contacting an Alliance member, or finding a solution elsewhere.
john m
(3,514 Views)
