Modem Comms won't work the second time
Howdie there folks,
I'm having a bit of a problem, I need to transmit small text files over a modem link so I found the "Transferring Logged Data from the FP-20xx through Serial Modem Communication" programs at
http://zone.ni.com/devzone/conceptd.nsf/webmain/4B5DC1F4481A33F286256B4A007D0216?OpenDocument
I can hook up the two machines and the transmission will work the first time but when I try to run it again the modems don't respond. I think that its got something to do with the closing of the comms port because when I run it the second time it says it fails to initialise. To get it working again I have to close down labView and run it again.
Any help would be appreciated
Cheers
Andrew
90% of all experts aggree that 1 out of 10 experts are wrong
(3,067 Views)
Make sure the serial ports have been properly closed when finshing the vi's! Even in case of an error the close_port should be performed.
Message Edited by LuI on 05-11-2005 08:57 AM
(3,066 Views)
