Multiple Character Termination
I am currently working on a device that its termination is '\r\n' reading the documentation NI-Visa can only do single termination and there is a way around it which I saw the answer using lab view. My project is in VBA so how do I set the termination to multicharacter termination?
Set instDPM5000 = New VisaComLib.FormattedIO488
Set instDPM5000.IO = ioMgr.Open("ASRL5::INSTR")
instDPM5000.WriteString ("*IDN?")
response = instDPM5000.ReadString()
Dim serInfc1 As VisaComLib.ISerial
Set serInfc1 = instDPM5000.IO
instDPM5000.IO.TerminationCharacterEnabled = True
instDPM5000.IO.TerminationCharacter = 13
serInfc1.EndIn = ASRL_END_TERMCHAR
instDPM5000.WriteString ("DPM value")
result = instDPM5000.ReadString()
(764 Views)
You don't, NI VISA only allows for a single character but why not set it to terminate simply on \n? That's how things are done in LabVIEW too!
Rolf Kalbermatter  My Blog
(738 Views)
As already stated, you just use the last character as the termination character. In this situation, you need to set the Termination Character to 10 (\n).
(724 Views)
