Multiple PC's To Access One Agilent E4263B LCR Meter - How to handle concurrent access request
Hi All,
In my system, I connect multiple PC's to Agilent E5810A (GPIB/LAN Gateway) through LAN Cable (through a multiple switch), and then from the GPIB Gateway, an Agilent E4263B LCR Meter is connected to it through GPIB.
I understand that the LCR Meter can only grant access to 1 PC at any given time.
Is there any IVI / VISA API's that I can use to handle conccurent request from more than 1 PC?
For example, any "LOCK" function that is available?
Thanks.
(3,427 Views)
Hello ChunK,
       I don't think that there is any built-in functionality that does what you are looking for.  You will probably need to implement your own solution.
Cheers,
NathanT
(3,417 Views)
You could use only one PC to acquire, and share data with others.
(3,402 Views)
