Multiple sensors connect to PIC Microcontroller
if your divace couldsend data without any thing to wirte into it so your visa method is correct
Message 21 of 28
(2,950 Views)
In this way how can i represent five data to five temperature meter???
Message 22 of 28
(2,943 Views)
zakariaislam17@yahoo.com wrote:
Note:PIC controller only sending data serially and each data separated by "LF(Line Feed) "it is  not get any Acknowledgement form PC.
If you have the capability of changing the code in the PIC, then you want the values seperatred by a comma and then have a Line Feed at the end of your message.  So your message should look something like "1,2,3,4,5LF" (where the LF is a line feed).  Then you have the LF be the termination character.  So you just tell the VISA Read to read more bytes than will be in a message (something like 50 should work) and then use Spreadsheet String To Array with the delimiter set to a comma.
Message 23 of 28
(2,934 Views)
Thanks crossrulz
Message 24 of 28
(2,895 Views)
What exactly do you mean here?  As long as you are dealing with the same data type (in this case, likely DBL), then you can have whatever sensor data you want in the array.
Message 25 of 28
(2,884 Views)
So fare i worked with only one type of sensor now i want to work with different type sensor .Before i had only one tpye of five sensor .Now i have five different type sensor .I am receiving five data, each of them is seperated by comma and end by "LF" (e.g "45,60,75,40,78LF),Is it possible to put them in five meter.
Message 26 of 28
(2,881 Views)
hi again it seem your problem is not fix yet
could you tell us what is your different data is ?
you have to convert them to related data type to use in meter
Message 27 of 28
(2,879 Views)
The short answer is yes.
Slightly longer answer: You can put whatever you want into that array.  It is just a matter of how you encode the data on the PIC side and making sure you interpret it the same way on the LabVIEW side.  Just making things up here.  Let's say you have 3 thermocouplers, a barometer, and an anemometer.  So on the pic side, you have all of those sensor data seperated by commas (one number for each sensor).  On the LabVIEW side, you make the array of numbers and then just use Index Array and/or Array Subset to get the specific value(s) you want for each calculation/graph/indicator/log.
Message 28 of 28
(2,878 Views)
