My DSA Scanivalve VI says it collected the data and saved,but the saved file doesnot show anything except zeroes.
Hi, I have a DSA Scanivalve 3217(16 port/channel pressure transducer).It communicates to the PC through a TCP/IP connection.I got this VI set from someone i cannot contact now.All The VIs i think are OK.But i donot know where it is going wrong.The output text fille shows all zeroes.
 So far i have made progress by able to communicate with my DSA pressure module(via TCP/IP).But the saved file shows zeroes under each channel even under some applied pressure conditions.There are no warnings or errors generated.
 Please find the attached set of VIs i got.They were not done by me.I am only a month old in LabVIEW....So please donot be harsh,if i have posted any simple/stupid doubt.
 If there is any one familiar with the Scanivalve Operation using LabVIEW,it would be great. Smiley Happy
Mitra
(4,608 Views)
I am using the same Scanivalve and experiencing the same problems.
Do you have the driver for that Scanivalve?
Thanks in advance.
(3,995 Views)
I have DSA 3207 . Can you provide me how to get the data from it?
(3,792 Views)
I have the same problems, please how did you solved it?.
(3,430 Views)
Hello, have you tried emailing techsupport@scanivalve.com with this issue? Aaron, one of the Scanivalve engineers, can help you with this issue.
(3,261 Views)
