My PCI 6341 AO Channel is not Functioning
I was experimenting in real-time and using AO Channel 02 of PCI 6341. It was working fine but suddenly I got some error and the voltage at the output of the channel went to a constant value of 13.3V.
I performed a self-calibration test it failed.
Then I used DAQ Diagnostic Utility and it showed me that my AO is functioning properly.
How to solve this problem?
And why does this kind of problem occur?
(1,933 Views)
Hello there,
Can you please provide the error code/message that you got?
(1,899 Views)
I didn't get any error at that time, but when I went to NI MAx >> Devices and interfaces and wanted to do self-calibration I got the following error
(1,895 Views)
Looks like you damaged the analog output somehow. Seems like you’ll have to contact NI technical support to arrange a RMA so they can repair it.
Rolf Kalbermatter  My Blog
(1,865 Views)
I agree with Rolf. It seems like the output doesn't function properly. Please contact NI Support.
(1,844 Views)
