It is apparent that the Applications Engineer did not bother reading the problem. Obviously, the person posting the problem had did a search on NI's site and saw the comments regarding VB, which the Application's Engineer just repeated. Hmmm...I need to insert an ibon(n,0) call to clean up? Well, where can I download the source code to MAX so I can fix the problem.
I too have this same problem - new install, Win2k SP2, and MAX. Nothing else. Yet, scan for instruments and its BSOD. This is clearly poor programming on the part of NI - BSOD are the responsiblity of the developer to prevent whilst running their applications.
