NAT9914
Although the system which used NAT9914 is under development, an actual interruption factor and the contents of ISR0 and ISR1 are not in agreement. Although an error may be in an initialization procedure, are there any notes? Access to a AUXCR is vacating sufficient interval.
(3,745 Views)
It already solved.
(3,745 Views)
