.NET API Member ibfind() Reading gpib.ini file
We are converting some legacy control programs and rely on the gpib.ini file for the configuration of instrumentation configured on each controller. I am looking for a .NET compatible command for ibfind().  The NET mapping help file indicates that the Board .NET member is equivalent to the ibfind C API member but I don't see any syntax where it's used.  Any help would be appreciated.
(2,755 Views)
Hey,
Can you share some of links from those documents you are referencing? This could give us a good start to help you out.
Brian J.
(2,735 Views)
