NI-488.2 1.7 Installation Wizard: Internal Error 2889
When installing NI-488.2 Version 1.7, the Installation Wizard terminates with the error message "Internal Error 2889. License_Dialog, License". It does not matter if the board (PCI-8212) is installed or not.
The system I am attempting to install the software on is an Intel Celeron system running Windows 98.
Any ideas?
(3,319 Views)
Hello-
I've never seen this error before. When searching google.com, the following was suggested:
-This situation can be caused by the W32.Nimda.A@mm virus. Run the Nimda Fix tool and reinstall MSI.
-Some customers have successfully used the steps in the document Error: "Configuration data for this product is corrupt" when installing Norton AntiVirus Corporate Edition 7.5, which use Instmsia.exe (Windows 9x) or Instmsiw.exe (Windows NT) to reinstall from the CD.
-If you are installing from a network, then install NAVCE locally in Safe mode (Windows 9x) as an unmanaged client, but do not reboot until the installation is complete.
-Verify that a NAVCE Primary Server is selected. Symantec has received reports that this error message will displ
ay when a Primary Server has not been selected.
See http://service4.symantec.com/SUPPORT/ent-security.nsf/3d2a1f71c5a003348525680f006426be/f6fabf955cffd2d988256acc005a3aa7?OpenDocument for more details.
Randy Solomonson
Application Engineer
(3,319 Views)
