NI-488.2 Linux SMP Support
Is there support for SMP under the current NI-488.2 Linux driver. If not, is there any way I can get the driver to install under a SMP kernel?
(3,292 Views)
I assume that you're talking about the GPIB driver for PCI GPIB and other cards, and not the one for ENET/100 GPIB interfaces.
From what I understand, this should work. If you can get the driver to compile under an SMP kernel, the driver should be thread-safe in the kernel. Are you having problems getting it compiled, or are you just curious?
Let me know how it goes.
Scott
(3,292 Views)
