NI-488.2 (Win32) Version 2.1 and DPIB32.PAS
I noticed mention of new header files in the documentation for this update. Does anyone know if the DPIB32.pas library for delphi is compatible with the update?
(3,682 Views)
Version 2.1 is completely backwards compatible with version 1.7. There are new header files, however the old header files are still fully supported. You should not need to recompile your application to use the new driver.
(3,682 Views)
